PXI
Can the software determine what PXI cage is attached
Can you try explicitly referencing the 1042's backplane when it's connected, even though it doesn't show up with viFindRsrc()? You should be able to find chassis information in Measurement and Automation Explorer
Justin E
National Instruments R&D
Message 11 of 13
(1,703 Views)
I tried to call the backplane on the PXI-1042 but that didn't work.  I'm not using MAX.  Then my program is loaded on to a computer it needs to be able to determine which PXI cage is attached.  The PXI-1056 reports back its ID but the 1042 does not.  How can I determine which PXI cage is attached just using calls is C++ not using max.
Message 12 of 13
(1,628 Views)
I open up MAX and it said the PXI-1042 cage is unidentified.  But if I attach the PXI-1056 cage it is identified.  DOes the PXI-1042 not identify itself to the software like the PXI-1056?
Message 13 of 13
(1,627 Views)
