01-13-2010 03:45 PM
Installed LabVIEW 8.5 RTE
Installed LabVIEW 8.5 (Eval)
Installed NI-Serial V3.5.0,
Next installed two PXI-8420 16 port serial cards,
System found many new devices that installed successfully - many to do with the serial cards,
Remaining item: System found new hardware "PCI Device"
Can't find driver for device
In the past installing NI-Serial would fix this.
What to do?
01-14-2010 10:07 AM
Hi Jeff,
I would start by looking in Measurement and Automation Explorer to determine if one of your serial cards is not showing up or if this is a 3rd card that doesn't have drivers.
If it is a serial card that is not showing up, you may want to try putting th card in a new slot, this sometimes helps cards get recognized.
Let us know what you find.
Scott M.
01-14-2010 01:06 PM
01-14-2010 04:51 PM
If all your serial ports are showing up properly then the PCI device is probably un related to NI-Serial, are you expecting any other cards to be present that aren't showing up in Measurement & Automation Explorer?
The following knowledge base article might help you determine what kind of card your dealing with:
PCI Simple Communications Controller
Scott M.
