PXI
Can not get PXI 4070 to show up as NI DAQmx device
(3,409 Views)
Welcome to the discussion forums, blfink!
How does it show up? Have you installed the NI-DMM driver? If not, you can find the latest driver by visiting www.ni.com/downloads » Drivers and Updates and search for “dmm”. Currently, the latest driver is 2.7.2 and is compatible with Windows 2000/XP, and Vista for the 4071.
If you have installed the driver, then will you please provide me with information about the software you have installed, such as versions of LabVIEW, Measurement & Automation Explorer (MAX), and NI-DMM?
Mark E.
Precision DC Product Support Engineer
(3,389 Views)
Thanks for your reply.  Installing NI-DMM 2.7.2  solved my problem. This was the third of three idendical systems, but the only one with a HP DC5700 PC.  The other 2 were Dell workstations which ran fine with the older driver.
(3,386 Views)
