PXI
Cable to interface with a terminal block while using PXIe-4340?
I cannot find any type of cable to use with the PXIe-4340. I would like to be able to connect a cable from the module to a terminal block. Any suggestions on what to use? Or how to do this?
(1,123 Views)
PXIe-4340 and TB-4340 User Guide and Terminal Block Specifications
You can use TB-4340
https://tmesystems.net/
(1,115 Views)
Hi, thank you. This is part of what I need, however, I also need a cable/wire. Any suggestion?
(1,110 Views)
