05-21-2019 12:29 PM
I am looking for pinout's and color code by pair for the following cables: 782417-03 and 779038-02. I need to confirm which wires inside are which color and connect to which pin on either end. Also to see if/how they are grouped and/or twisted. I am running from one PXI card to another, then to a switch card and back out to a DUT Tx and Rx. I need to know if I can use these cables, or if I have to just order the connectors and do my own discrete wiring. Thank you.
05-22-2019 09:43 PM
I have attached a few links that should help provide a bit more information for the cables. The first cable did not have any pinouts available, however, I was able to find some information on compatible PXI cards. As for the second cable, I think that you are looking for the LFH200 information so those are included below.
782417-03 Cable Info: http://sine.ni.com/nips/cds/view/p/lang/en/nid/212026
779038-02 (LFH200 Dimensional Drawing and Cable Installation):
http://www.ni.com/en-us/support/documentation/dimensional-drawings/model.lfh200.html
http://www.ni.com/pdf/manuals/373848f.pdf
Hopefully this helps!
Megan T.
Technical Support Engineer
05-23-2019 06:18 AM
Hi Megan,
That was perfect for the 200-pin. Another NI person sent me some additional info on the 160, so I now have the pin-out of which d-sub ends up with which pins from the other end, but still need to know whether or not the wires inside are twisted pairs or not. Can I assume that the colors on the flying lead cable are the same as the (4) 50-pin d-sub cable? The two PXI cards I am using this cable with are the 2526 and the 2576.
Best Regards,
Kris
05-23-2019 11:50 AM
Hey Kris,
I looked into the 160 pin cable and it seems like the wires inside are not twisted pairs. As for the colors, they should be the same.
I did a little digging into the compatibility for the PXI cards and the cables and this is what I found:
160 pin should support the following:
200 pin should support the following depending on the configuration used:
Best,
Megan T.
05-23-2019 12:26 PM
Hi Megan,
Thanks for the info, I have one more cable, I missed it earlier, your latest reply got me to find the error on my end. For the 2576 card, I need to use p/n 780009-01. Can you send me the pin out of each end and pairing/color scheme for that as well?
Best
Kris
05-23-2019 02:00 PM
Hey Kris,
Attached is the installation instructions for the LPH 160 cable (Part Number: 780009-01). Hopefully this is what you were looking for!
Installation Instructions LFH160 Cable
http://www.ni.com/pdf/manuals/374694b.pdf
Best,
Megan T.
05-23-2019 02:12 PM
Hey Megan,
That is a great help, last question, are they twisted pairs or no? I am assuming no.
05-23-2019 02:18 PM
Hey Kris,
I couldn't find any information verifying it was twisted pair so I would assume not.
Best,
Megan T.
