04-28-2014 11:55 AM
I'm having a problem with the PXI-8170 Controller, the system does not start due the CMOS Battery Failured. I'm attaching a image with the error.
If I press F1 to continue, the system does not start and stays in black screen.
Thanks.
J. Frantz
04-29-2014 09:35 AM
Hello Julio,
This problem can be caused from battery disconnected or it is discharged not working well, being needed its replacement. This battery is connected on mother board of the controller. Certainly it is time of replacing it.
This links lists which is the battery used in your PXI controller.
http://digital.ni.com/public.nsf/allkb/B34E19F5A19E8BBB86256BE500562516
Any questions let me know.
Thanks.
04-29-2014 10:05 AM
Hello lferreira,
Thanks for the reply.
Yesterday I found the battery on the PXI processor, it's a Timekeeper M4T28-BR12SH1, DataSheet here . I will try to change the battery, first i need to buy it.
I found a supplier here in Brazil.
Thanks.
Julio
05-19-2014 11:57 AM
I changed the Battery, and the PXI is working now.
Thanks.
