PXI
Reply
Baud rate PXI-8516 troubles
Does anyone has troubles with PXI-8516 baud rate?
Let me explain, if I set the LIN baud rate to 9600 I can communicate with my system but if I put 19200, the PXI 8516 is completetly out and there's only the identifer on the network, no more datas.
I use the same system with a USB 8476 without problems at 19200 bd/s.
Does someone has an idea of solution?
I don't know you but I prefer using the NI-CAN drivers than the NI-xNET one. Examples and documentation of the NI-xNET is simply horrible.
In my system, I just have to generate sporadically messages without any scheduler or event triggered and it has been so difficult to do it...
Message 1 of 1
(3,449 Views)
