PXI
BSOD on PXIe-8840 running Windows 7 64
Good morning,
We had implemented an ATE, to run long time test, with the PXI in object. During the preliminary test we encountered problems due to the BSOD of W7 after some hours (within 12 and 36) of continuosly running.
I have check the memory dump of the errors, via WinDBG, and seems to me that problem is CPU related (maybe heat?) due to corruption of the cache memory. The application running on it was completely developed with Labview.
I attach the revelant result of the dump analisys:
BugCheck 124, {0, fffffa800530b028, be000000, 100110b}
*** ERROR: Module load completed but symbols could not be loaded for igdkmd64.sys
Probably caused by : GenuineIntel
Followup: MachineOwner
0: kd> !analyze -v
* Bugcheck Analysis *
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa800530b028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000be000000, High order 32-bits of the MCi_STATUS value.
Arg4: 000000000100110b, Low order 32-bits of the MCi_STATUS value.
Please we need help for this situation.
Thank you very much,
Francesco.
(2,817 Views)
Please, anyone? Just tried to update all windows 7. Same Crash.
(2,660 Views)
