PXI
Automated Increasing Voltage is not output from the loop
I have to provide increasing voltage (Linear/Logarithmic) into my test board. I created a program in LabView and while the output is visible on the waveform chart that is in the loop but there is no output voltage on the wire terminal. I have PXI4130 and PXI4110 on my PXIe1085 chassis. Is there a need to bring the output indicator out from the loop or it should provide the voltage on the pxi card?
When I take the output voltage indicator out of the loop, I only get the final value. I need rising voltage to be input in my test board at certain time intervals.
(269 Views)
In your code, you're not using any NI DC Power drivers to control the Power Supplies or SMUs.
Quick primer,
  • To control any hardware, you need to use it's driver functions
  • To control PXI-4110 and PXI-4130, you need to use NI DC Power driver functions
Santhosh
Soliton Technologies
(255 Views)
Oh i am sorry.. I attached the wrong VI here is the one i was talking about.
(244 Views)
