11-18-2020 09:51 AM
One of the projects I am working requires me to adapt a LabVIEW project that was originally written to be used with the PCI-7831R so that it is able to run on the NI MyRIO. I have only recently started working with FPGAs and LabVIEW, and was wondering if it's possible to run code on a MyRIO that was originally written for the PCI-7831R without having to completely re-make the project.
11-18-2020 10:01 AM
Create a new target in your project for the myRIO. You can copy the code from the PCI-7831R target to the myRIO FPGA target. You will then probably have to fix all kinds of stuff (IO, FIFOs, etc.).
