12-03-2020 04:04 AM
I have the same connection as above.
In this connection, I did the following coding through Labview, but the error code 7 is displayed like under.
How can this problem be solved?
Please answer as many as possible.
12-03-2020 06:23 AM - edited 12-03-2020 06:25 AM
Did you deploy to the remote controller? What OS is running on the remote controller?
EDIT: I just noticed you have RT installed on the remote controller. So issue #1 is that you have to treat the PXI chassis as a different computer, because it is. It cannot save a file directly to your PC. Save the data to a folder on the controller and then use WebDAV or FTP to copy the file to your PC.
