02-27-2018 02:51 AM
Got the ACXX1553-3U-x-DS PXI card in an NI-1045 PXI chassis and after installing the AIM drivers on the PC, it flags up that the drivers weren't installed correctly. Device manager sees the card but with a driver problem. Anyone used this 1553 card in the PXI-1045 chassis and got it working?
Cheers
Stuart
02-28-2018 07:12 AM
Hi Stuart,
I haven't used this special 1533 card with a 1045 chassis, but from my experience with similar cards I would say that the chassis is a very unlikely cause for this driver problem.
- which type of controller are you using and which operating system are you running?
- did you try to reinstall the drivers? maybe just something went wrong with the installation
- Did you check with AIM if this is a known problem? Driver problems are typically rather associated with the card itself or with the OS instead of the chassis
Andreas Jost
03-05-2018 09:30 AM
HI,
The NI-PXI-1045 rack is linked by an NI PCIe MXI4 card in an Amplicon Industrial PC running Windows 7 64 bit.
I have re-installed the drivers a number of times but still the same.
I am in contact with AIM on this matter too and have tried all steps they have suggested but to no avail. I have tried the setup in a different PC but makes no difference.
Stuart
