PXI
782887-01 for PXIe-4112
We have one ATE that uses two PXIe-4112 power supplies to power the UUTs.
The ATE has been in service prior to my arrival with the company four years ago.
The company built a second ATE.
We were experiencing a symptom of intermittent power supply voltage and traced it to the mating connector, 782887-01, that connects to the PXIe-4112.
Under a microscope, it is observed the the original ATE mating connector's pins are in the housing at a slight angle.  While the new mating connector's pins are straight.
Three new connectors were ordered from digikey.  They, too, have the same symptom.  Examined under a microscope, the connectors also have a straight pins.
I'm looking for the drawing for the connector.
Message 1 of 1
(191 Views)
