11-06-2017 01:36 AM
Hello
I want to use pxie 10MHz CLK in my FPGA code as IO port, but this CLK isn't accessible. what should I do to accessing this CLK?
11-06-2017 04:02 AM
In the project, you should be able to right-click on the FPGA Target and add IO. The PXIe reference clock should be in the list of available IO.
11-06-2017 08:24 AM
thank you crossrulz
I checked that list but there wasn't 10MHz reference CLK.
11-06-2017 08:40 AM
With PXIe, you might only have access to the 100MHz clock (have not had to do this with a PXIe yet). Would that work for you?
11-06-2017 09:06 AM
I want to use pxie ref CLK for synchronization, I didn't find pxie CLK 10 , so when I want to use CLK 100 in generating intermediate file step, it has an error:
" An internal software error has occurred. Please contact National Instruments technical support at ni.com/support with the following information:
Error 7 occurred at Read from Text File in niFpgaCodeGeneration_GetBuildResultsXML.vi->niFpgaErrorDialog_ReadErrorData.vi->niFpgaGenerateCode_ErrorDialog.vi
Possible reason(s):
LabVIEW: File not found. The file might be in a different location or deleted. Use the command prompt or the file explorer to verify that the path is correct.
C:\NIFPGA\compilation\test_PXIe-5170R(8CH)_StreamToHost(FPG_Q4sbNjgPnqI\BuildResults.lvtxt"
