PXI Community
Reply
Highlighted
Phase Matrix PXI-1450 Local Oscillator Module
Product DescriptionProduct Information
The PXI-1450 Local Oscillator Module is a PXI 3U, 2-slot synthesizer module intended for frequency down conversion applications. The PXI-1450 is a VCO-based, 3 to 9 GHz synthesizer capable of a tuning resolution of less than 1 Hz. It is optimized for speedy (1 ms) settling time to allow for fast frequency down conversion applications that employ Phase Matrix models PXI-1420 MW Downconverter Module (2.7 to 26.5 GHz) and PXI-1430 RF Downconverter Module (100 kHz to 2.9 GHz).
The PXI-1450 contains all the circuitry necessary to lock the synthesizer and a 100 MHz ovenized crystal oscillator to an externally provided 10 MHz master reference oscillator. This capability enables the module to distribute its internal high-stability reference or the customer-provided external reference to other PXI modules within a PXI mainframe chassis.
The PXI-1450 is intended for use in applications such as synthetic instrumentation, microwave receivers, signal intelligence, or anywhere a microwave signal needs to be down converted to a baseband frequency for data capture, analysis, and measurement.
Company: Phase Matrix, Inc.
Product Name: PXI-1450 Local Oscillator Module
Recommended NI products: NI PXI Chassis, NI LabVIEW, NI PXI Digitizers
Official Product Site: http://bit.ly/PXI_SI
Message 1 of 1
(5,233 Views)
Reply
