PXI Community
Reply
Highlighted
MAC Panel - SCOUT Mass Interconnect
CompanyProductWebsite
MAC Panel
http://www.macpanel.com/scoutlanding.aspx
Seeing is believing. Check out the "Ease of Use" video on the link above.
Then you'll realize the brilliance of SCOUT
SCOUT from MAC Panel is a configurable Mass Interconnect system that provides a PCB or short wire interconnection for your PXI based test system.
Each PXI instrument is attached to a receiver connector module via a Direct Access Kit (DAK)SCOUT receiver. adaptor, providing direct connectivity between the PXI instruments and the
All instruments are easily installed or removed through the front of the receiver, without disturbing the system wiring. DAK adapters utilize standard MAC Panel  Series connector modules, providing a wide variety of contact types: with  signal, power, coax, RF and hybrid combinations available. The  connection between the PXI instrument and receiver module is  accomplished using either printed circuit boards or flex circuits,  providing optimum connectivity performance while reducing wiring cost.  Where a wired solution is preferred, the DAK adapter provides for a short wire alternative to traditional hinged mass interconnect receiver designs.
Message 1 of 1
(4,228 Views)
Reply
