Next Steps - LabVIEW RIO Evaluation Kit
Simple Hello World app error on sbRIO9637 Eval Board
I received my eval board last week and I successfully executed all the Hardware based Labview tutorials. I turned to the C/C++ tutorials and I encountered a problem. After a lot of work to set up the Eclipse environment I compiled the Hello World example successfully. I then followed the instructions to  run the example on the board and it gave an intermittent result error then suddenly worked for both release and debug configurations. I started the C/C++ tutorial and after getting it to compile I got the same error. I went back to square one today and ran the simple Hello World app. It now gets the same error consistently, here is what I get:
Error during file upload.
Operation failed. File system input or output error
I thought it might be a timeout but changing launch timeout had no effect. I must be doing something wrong but I don't know what.
(5,380 Views)
Solved it was finger problems with the Run configuration dialog box.
(5,358 Views)
