08-14-2013 04:41 PM - last edited on 01-19-2024 10:03 AM by migration-bot
Exercises and matching manual saved for LabVIEW 2011 SP1, 2012, 2013, and 2014.
To use with the LabVIEW RIO Evaluation Kit hardware you will need the NI-RIO 4.1, 12.0, 13.0, or 14.0.1 driver respectively and the LCD Character display driver, available here or through the VI Package Manager.
09-11-2014 08:01 PM
In the exercise 2: Create FPGA Application I was not able to vary the RPM with the knob as stated in the Tutorial. It stayed in 0 all the time... And the LCD screen stayed akso with black boxes over each character space. Help Please!
09-12-2014 08:34 AM
Hi reqp,
Thanks for posting! The LCD screen behavior you are seeing (or not seeing) is expected, and it will begin updating after exercise 3. For the RPM, here are some troubleshooting tips:
Hope this helps! Please post again if you're still seeing RPM as 0.
Deborah
09-12-2014 12:20 PM
Hi Deborah,
I already tried what you posted. I am even running the solution included
with the exercises and still 0 rpm. Is it possible that the Hardware came
faulty? If so, what should I do? my 90 day evaluation are still running...
Regards
09-12-2014 03:40 PM
Hi again Deborah,
Nevermind, found I was using a broken wire in my connection between Signal
Generator and FPGA's ADC.
Thanks a lot for your prompt answer
09-15-2014 08:29 AM
Great to hear everything is working! Please reference some of the other examples found throughout this group once you've completed the tutorial. Best of luck with your application!
