Next Steps - LabVIEW RIO Evaluation Kit
Connect thermocouple and I2C sensor
Good morning, i have a signal from a thermocouple K with milivolts changes, i need to amplify before the analog input or the analog input has sufficient accuracy to treat this type og signals?. Moreover, ihave a signal from a sensor in I2C protocol, what entry can i use?. Thanks and sorry for my English i speak Spanish.
(7,806 Views)
Hello RIHERSA,
Let me make sure I understand what you're asking.
1) Are the analog input channels on the Evaluation kit accurate enough to detect mV changes from a thermocouple or will you need to amplify the signal before inputting to the channel?
2) How to communicate with an I2C sensor?
1) The evaluation kit is built on a sbRIO-9636. Starting at page 26 of the operating instructions for the 9636, gives you information on the Analog Input for various voltage ranges.
2)Here are some specific resources for SPI and I2C communication on LabVIEW FPGA:
FPGA IP (IPNet): Digital Buses and Protocols (SPI, I2C, and Serial). This ties together a number of example VIs related to I2C on FPGA
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209123
SPI and I2C Driver API - National Instruments
http://sine.ni.com/nips/cds/view/p/lang/en/nid/210637
Community Beta Example: I2C Implementation in LabVIEW FPGA
https://decibel.ni.com/content/docs/DOC-1151
Reference example-Simple I2C Communication to DAC IC using LabVIEW FPGA
http://zone.ni.com/devzone/cda/epd/p/id/3975
Hope this helps!
Deborah
Deborah Burke
NI Hardware and Drivers Product Manager
Certified LabVIEW Architect
(5,532 Views)
Thanks for you answer!
Know i try to read a GPS by Rs232, i imagine that exist one VI for this but i don found the input in the pin out.
(5,532 Views)
Hi RIHERSA,
You can use our basic VISA VIs to do RS-232 communication. I did a bit of searching on ni.com and found a case study for GPS where they also included a PDF with screenshots of their code. Here is also another customer-posted example.
Hope this helps!
Deborah
Deborah Burke
(5,532 Views)
Thanks very much!
(5,532 Views)
