Network Analysis
Reply
Highlighted
InMMIC 2014 - Leuven, BE - April 2-4, 2014
http://www.inmmic.org/
Presentation
"Optimization of a Next-Generation Comb Generator for Accurate Large-Signal Measurements on a User-Defined Frequency Grid"
P. Barmuta, F. Verbeyst, A. Lewandowski, D. Schreurs, KU Leuven / Warsaw University of Technology / National Instruments
Session III: Advances in Nonlinear Measurement Techniques - April 2nd, 2014 15:20-16:40
In order to accurately calibrate measurement instruments at RF and microwave frequencies, periodic pulse-shaped signals are used. However, when performing modulated measurements, the repetition rate of this pulse-shaped signal has to be kept very low. As a result, it is almost impossible to measure such a signal using state-of-the-art instrumentation due to the required signal-to-noise ratio. Recently, a next-generation comb generator using Pseudo-Random Bit Sequence (PRBS) has been proposed. It allows to generate dense modulation tones around the carrier and its harmonics and to balance the power of these modulation tones and the desired modulation bandwidth. Moving it one step further, the energy can be optimized for a desired number of discrete tones using a Tone Selective Bit Sequence (TSBS) instead of a PRBS sequence. In this paper two methods are presented to realize such a TSBS using a geneticalgorithm as part of a global optimization. It is shown that these methods outperform the initially proposed method which is based on random phase and clipping, especially when the number of desired tones increases.
Exhibition
Visit National Instruments and AWR booth
View live demonstrations of NI products such as performing fast load-pull characterization under CW and modulated conditions using a NI PXIe-5644R Vector Signal Transceiver (VST) and a Maury Microwave Tuner and importing results in AWR Design Environment.
Message 1 of 1
(5,401 Views)
Reply
