Network Analysis
Reply
Highlighted
High Frequency Network Analysis Library
The High-Frequency Network Analysis Library contains different functions:
- to read network parameters data files in several formats (CITI, MDIF, Touchstone,...),
- to design grid and sweep patterns and to calculate derived quantities for load-pull applications,
- to cascade networks and transform network parameters (S,T,ABCD),
- to convert quantities in different units,
- to display S-parameters data in different formats.
Compatibility
LabVIEW Versions: 2012 or higher
Compatible OS Versions: Windows
End User License Agreement
National Instruments Software License Terms (Sample Code)
Installation
 - Download the High-Frequency Network Analysis Library VI package
- Open the VI package using VI Package Manager. For more details, please read A Note on VI Package Manager
- Select the LabVIEW version for which you want to install the High-Frequency Network Analysis Library
- Click on Install and follow the installation steps
- After installation, the High-Frequency Network Analysis Controls and Functions are available in the LabVIEW Controls and Functions palettes under Addons>HF Network Analysis
Examples
After installation, different examples are available in the LabVIEW installation directory under examples\HF Network Analysis\Examples.
Version Log
1.0.2.2
- Fix bug when writing SnP to file (row vs column major ordering)
1.0.1.1
- Fix bug when loading a 1 frequency point SnP file
1.0.0.26
- Adding support for SnP Output Data Type property
1.0.0.25
- Fix dependency bug
1.0.0.24
- Fix culture language to en-US
- Use major-row 2D Array format instead of Touchstone format
- Add CITI File Viewer, MDIF File Viewer and SnP File Viewer as examples
- Add  CHM help file and update VI context help accordingly
- Add S-parameters Graph Control and associated functions
1.0.0.15
- Initial release
Message 1 of 1
(3,168 Views)
Reply
