National Instruments Circuit Design Community Discussions
Reply
how can find any one equal transistor and any one electronic parts
So I iam newly of electronic field and subject. I want knowledge that area of electronic circuit.
So how can find  any one equal transistor and  any one electronic parts.
For example is :-
so I have a data book. I find C828 that transistor. Then I tried that by multisim software ver 13. But I cant find that. So data book have comparison type is BC 327, BC638, BC640, 2SCB647.  So then I find that comparison type. So sad I cant find, please help me that how I can find comparison type model by data book to multisim software .
any type TRANSISTOR ,IC, CAPACITOR, OR ETC
Hear with attached of image of data book and multisim software
Thank you
I am sameera
Srilanka-
Message 1 of 12
(5,790 Views)
Re: how can find any one equal transistor and any one electronic parts
Hello sameera,
I found the BC327, BC638, BC640 at the main database of Multisim 13.0.0 (13.0.632), database version: 13.0.a. Have a look at the attached screen shots. Perhaps you have to update your programm  and database.
I hope this can help you find your comparison type.
BC327.PNGBC638.PNGLenny
Message 2 of 12
(2,366 Views)
Hello sameera,
I think you could not find the comparison type, because you searchd for a npn-type transistor of the family BJT-NPN. If you select <All families> or BJT_PNP family you should find the comparison types BCxxx.
Best wishes
Lenny
Message 3 of 12
(2,366 Views)
Highlighted
thanks lot lenny sir. so my software update verion is ok. hear with attached of image. pls what is problebm .
thanks
Message 4 of 12
(2,366 Views)
Hi sameera,
have a look at my second answer...
lenny
Message 5 of 12
(2,366 Views)
Hi sameera,
You can find the answer at your post:
https://decibel.ni.com/content/message/81088#81088
Lenny
Von: sameerato@gmail.com
Gesendet: Freitag, 29. August 2014 13:55
An: lenny
Betreff: - Re: how can find any one equal transistor and any one electronic parts
<https://decibel.ni.com/content/index.jspa> Das Bild wurde vom Absender entfernt. National InstrumentsCommunity
erstellt von sameerato@gmail.com <https://decibel.ni.com/content/people/sameerato%40gmail.com> in National Instruments Circuit Design Community - vollen Thread anzeigen <https://decibel.ni.com/content/message/81088#81088
Message 6 of 12
(2,366 Views)
helow lenny sir. finaly i was sucessed and won. your second answer is wonderfull. thanks lot sir. hear with aataced my image is comparison transistor. ni mail.png
Message 7 of 12
(2,366 Views)
SIR LENNY .
               JUST I USING by multisim SOFTWARE AND CREATING MY FIRST LED circuit . then i after finaly run that circuit. but no led flashing, i dont know that it is flash or not. how is checking  this circuit working or not . and other i will try creating small circuit . but i dont know that checking wrong or corect. pls how to check ?
thanks lenny sir
sameera
srilanka (now time is mid ninght 12.50am) good night sir
Message 8 of 12
(2,366 Views)
Hi sameera,
first you have to contact your power source at the top to allow current flow through the parts.
You need in practice a current limiting resistor for your diodes and a switch to pull down the base of the first transistor Q2. Very important is a grount connector at the low potential of your power source. I have attached an simple example for switching two LEDs on and off.
Message 9 of 12
(2,366 Views)
thank you sir. so can you send that your simple example for switching two LEDs on and off multisim original running file. then i can that file open and run. thanks again sir for help me.
thanks
sameera
Message 10 of 12
(2,366 Views)
