Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
06-07-2013 03:48 AM
I know that Ultiboard is able to import DXF files.
But my customer needs to import a contour for his PCB. So the shape should not be edgy.
He is using Pro Engineer and maybe could also use a different file format, but he prefers DXF.
Thanks a lot for you quick replies in advacne 😉
Greetings from Austria
Bernhard
06-07-2013 08:30 AM
Hi Bernhard,
To import a board contour into Ultiboard, the DXF import could be used as well. Simply map the imported DXF shape to the board outline layer.
Thank you,
Mahmoud
06-10-2013 07:52 AM
Hi Mahmoud,
thanks a lot for your quick reply. The problem is that I do not know who to do it and also the customer does not.
Could you please send me a few instructions or screenshots how to do it?
This would be really great.
06-10-2013 08:43 AM
Here is a tutorial on how to accomplish this task:
http://www.ni.com/white-paper/13722/en
Let me know if you need anything else,
06-10-2013 08:45 AM
thank you so much!
Sure I will 😉
Thanks!
We'll be in touch soon!
