(Make sure you follow all the 3 steps involved in submission. This is only Step 2 of 3. For details, visit http://bit.ly/16iNfUL)
Contact Information
Name of the College :Prathyusha Institute of Technology & Management
Name of the Team Members along with their respective current semester :
T.Guru Prasath - 7th sem
U.Jagadeeswaran - 7th sem
R.Arun raj - 7th sem
E-Mail Address & Phone Number of the Team Leader :rajaaguru2010@gmail.com
9698384869
Name of the Faculty Guide :Mrs. Kalpana Devi P
E-Mail Address & Phone Number of the Faculty Guide :
9962688222
Project Information
Project Title: Automated CNC(Computer Numerical Control)
Hardware & Software Used:
What challenge/problem are you trying to solve through your application:
We are trying here to convert an existing CNC which work on defined object to
an automated one which can be able to work on a undefined object like granite,marble,log,etc,.
How does your application solves the above mentioned challenge/problem:
We are over coming the challenge just by finding the edges of the object from its
image just by using the technique of edge detection and by using the tool of IMAQ machine
tools like caliper to find the distance between the two edges. Then, there by we can find the
size of the boudries in real time of the object we can take the control over Axial motors.
Description of Project:
The object is placed on the machinery bed. The camera which is mounted in front of the machine
will give the clear view of the object’s image to the system. Then by using the GCode technology
of coding the three axis (X, Y and Z) of the machine are controlled. This GCode technology ensures
greater efficiency and accuracy for better results. The three axis of the machine are generally predefined
but in this case, by the process of Gcoding it is being automated in order to perform work on a
undetermined/undefined object .This process of automation is done with the help of the labVIEW tools.
Then the Gcoded data is processed, interpreted and sent to the CNC/Machinery via the sbRIO external
interface kit. This will also provide a feature of surface leveling which helps the object to level it on the surface
bed.
Insert Images Here:
YouTube Link of Video:
Insert the Video here:
