NIYANTRA Discussions
[Group Q] NIYANTRA 2013:Ask Your Mentor
This is the team-mentor interaction space for all the NIYANTRA 2013 teams belonging to Group Q. If your team belongs to this group,this is the place you should be interacting with your mentors.
Make Sure You Read this Document Carefully Before Starting.
This group is being mentored by Mr Roop Ghosh &  Mr Srinidhi N  (National Instruments R & D)
Click here for the Group Allocation List
Message 1 of 10
(11,251 Views)
I am doing project on Developing of infotainment system for monitoring traffic rules and driver authentication.So i require a Single board computer with touchscreen which runs Windows Embedded in it.The best matching hardware which suits my project is NI TPC-2212(12 in LabVIEW touch panel Computer with Windows Embedded ). Will NI be providing with this hardware ?
With Regards
Sibin K Mathew
Email: sibin.is.here@gmail.com
Mobile No:+1215-406-6545
http://in.linkedin.com/pub/sibin-mathew/48/846/446
Message 2 of 10
(6,437 Views)
Sir,
We are doing a project that aims at automating the task of detecting empty shelves in a mall.So it involves Image processing and we need IMAQ vision for that.So can we get IMAQ vision on an evaluation copy of LABVIEW?or if possible can you provide us with this software?
Thank you.
Message 3 of 10
(6,437 Views)
sir,
we are doing project on multisensor security system.can a controllers like AT89c51,other sensor drivers can be interfaced to the labview software ,or we should use DAQ signal conditionig /compact RIO modules of NI.
Message 4 of 10
(6,437 Views)
i would suggest you use a DAQ for interfacing. NI USB 6009 might be helpful (http://sine.ni.com/nips/cds/view/p/lang/en/nid/201987)
You can look at using Elvis or a sbRIO which are available from NI as a part of NI Yantra hardware loaning depending on your requirement.
List of hardwares available for loaning
https://decibel.ni.com/content/docs/DOC-30191
Message 5 of 10
(6,437 Views)
Message 6 of 10
(6,437 Views)
I am sorry. It will not be possible to loan NI TPC-2212. We will only be able to loan  hardwares mentioned in the document @ https://decibel.ni.com/content/docs/DOC-30191
Message 7 of 10
(6,437 Views)
sir, based on the resources made available on the National instruments site we have selected the following software to work on :
NI labVIEW
NI IMAQ
NI Vision Assistant
IP WEBCAM (Android App)
we wish to acquire the image from a mobile phone working on Android ICS through an app called IP WEBCAM . Further , we found an article on ni.com which assists users to interface IP WEBCAM to any NI software. unfortunately we are not able to execute the final step of the execution.
i am enclosing the link of the article for your kind reference:
http://digital.ni.com/public.nsf/allkb/3D9CEA3E7B26FA4586257A56004E4507
further , we wanted to use Mathworks MATLAB for a part of the process. we learnt that NI offers its users the services of  MATLAB SCRIPT. We have not been able to find a link to download the above said script. we had even mailed NI India Technical Team but did not get any response.
finally the integrated webcam or the ip webcam from is not reflecting in my NI MAX al though i can acquire images from NI VISION ASSISTANT.  I need some help to debug that issue. please see the enclosed pic
thanking you
Message 8 of 10
(6,437 Views)
My project is "LabVIEW based Farm Autonation using Android", and I am working with Data Dashboard for Android, on a Sony mobile, and I have followed all the procedure to create, build and deploy a web service.
I am able to access the Web Server from the Data Dashboard application, and  I can also visualize the Web Services and their deployed variables.
The problem comes when I select a particular deployed variable; I am shown a message " no supported variable...", when I select this, i am taken back to the home page of  Data Dashboard.
I verified the data types of the network variables I used in my VI, and they are all supported by Data Dashboard.
Attached is an image of the message that I am getting on my mobile.
Anyone has an idea on what's actually happening, and the reason of this message??
I would be grateful for any help!!
Thanks in advance.'
Message 9 of 10
(6,437 Views)
sir,
   we are doing project on multisensor security system. Can we make sound generation in labview such as alarm to ring when the text is received at serial communication output?or we have to use only waveform to generate sound.if we can do with text,can u please send me information related to sound generation using text
Message 10 of 10
(6,437 Views)
