NI myRIO App Development
Reply
Highlighted
myRIO Application Developer's Tutorial, Example Code, and Sample Files
The attached tutorial references the Cool myRIO App zip folder, also attached.  The contents of the tutorial are as follows:
Contents1
Project Overview2
     Goal2
     Software and Hardware Prerequisites2
Step 1:  Review Requirements and Documentation3
     Join NI myRIO App Development Community Page3
     Understand the Application Goals and Requirements    3
     Determine Application Content3
Step 2:  Development and Implementation4
     Required Files4
     Source File Structure on Disk5
     Source File Specifics6
Step 3:  Building a VI Package9
     VI Package Builder9
     Post-Install VI Custom Action15
Step 4:  Submit to the LabVIEW Tools Network16
     Online Resources16
The zip folder contains the source code for a sample application, known as the Cool myRIO App.  The source code folder contains all files needed to create an application, including *.lvproj, html help document, XML metadata, Desktop Main VI, RT Main VI, subVIs, and Post-Install VI.
The built VI package is attached as well to demonstrate the end user experience.
Sample Post-Install VI, HTML help document and XML metadata files are attached separately from the zip for convenience.  These files are identical to the files contained in the zip.  For details on how to use these files, see the attached tutorial.
Patrick
CLA
(4,361 Views)
Re: myRIO Application Developer's Tutorial, Example Code, and Sample Files
Do you have an updated version of the NI myRIO Post-Install App Launcher.vi for versions after LabVIEW 14? I have users of the X-CAN for myRIO package experiencing errors when trying to create a new X-CAN project from the project wizard. They are recieving an error with the myRIOMetaDataObj.lvclass which gets called on-post execute from the VI package manager. This issue does not occur in LabVIEW 2014.
The exact error is: Error 1055 occurred at Property Node in myRIOMetaDataObj.lvclass:UpdateFPGARef.vi->myRIOMetaDataObj.lvclassSmiley TongueostCopyScripting.vi->NewProjectDialog.vi
LabVIEW: Object reference is invalid.
(1,561 Views)
Did you find the solution about the error 1055?
I have the same error with Labview 2016.
Lily
(1,501 Views)
hi,
i have the same problem...
have found a solution ?
UrmO
(400 Views)
Reply
