NI myRIO App Development
Reply
Highlighted
Interfacing myRIO VIs with MyComputer VIs
Hello--
We are trying to open and run myRIO VIs in another VI that was built on MyComputer using the invoke nodes available in LabVIEW; however, we are receiving errors. At this point, we need to manually open 3 myRIO VIs that the main VI on myRIO depends on. Is there a way to automatically open and run the 3 VIs when the Main VI begins to run?
Thanks in advance.
Message 1 of 8
(3,123 Views)
Re: Interfacing myRIO VIs with MyComputer VIs
Can you be more specific on how you are trying to launch the myRIO VI's? Are you trying to launch them asynchronously?
fka OlliesCamel
"I have Google for memory and Wikipedia for knowledge, mostly I use my brain for thinking up stupid things for my body to do."
Christopher Stryker | Staff Software Engineer | Certified LabVIEW Architect
Message 2 of 8
(2,436 Views)
We want the myRIO VIs, which are being used for data collection from accelerometers and other sensors, to automatically launch when the Main VI, which is being used for data processing, starts to run. Please let me know if you need further clarification.
Thanks.
Message 3 of 8
(2,436 Views)
There are multiple ways of launching the VI's.   It sounds as if you have a system that you have implemented, but is not working properly. Are you using VI server references? What invoke nodes are you currently using? Can you share snippets of your code?
EDIT: The following documentation outlines the process in broad strokes, but does not have any example code: http://zone.ni.com/reference/en-XX/help/371361M-01/lvconcepts/building_vi_server_applications/
Message was edited by: OlliesCamel to include additional information
fka OlliesCamel
Message 4 of 8
(2,436 Views)
We are successfully able to open up the VI (See attached). However, we are
not able to run the VI because the open VI opens up in MyComputer instead
of as part of the MyRIO (see the broken arrow). Please let me know if you
need more information.
Project outline
Message 5 of 8
(2,436 Views)
To be clear, how are you referencing these VIs? The first step should be to open an application reference scoped to the myRIO, as outlined here: http://zone.ni.com/reference/en-XX/help/371361M-01/glang/open_application_reference/  Following that, you will need to ensure that the VIs are properly deployed to the cRIO and are being referenced by the appropriate target-specific path.  Could you share screenshots of your block diagram where you are opening your references and such?
fka OlliesCamel
Message 6 of 8
(2,436 Views)
HI,
This VI that is being opened is being run on myRIO whereas the program that
is invoking the invoke nodes is pulling from myComputer. The Block Diagram
below describes how we are opening the file.
When we open the VI, it opens up in my computer instead of in myRIO. Below
is an image of the myRIO VI working independently of the main program which
runs on myComputer. If you look in the title it says .lvproj/myRIO-1900.
However, when I open it using the VI server, it opens as lvproj/My Computer.
Please let me know if you need more clarification.
Message 7 of 8
(2,436 Views)
You need to treat the myRIO like it is another computer.  The you should deploy an application to the myRIO and then use Network Streams, Network Published Shared Variables, or other types of network communication to get your data.  Since you are talking about data collection, I would use the Network Streams.
Message 8 of 8
(2,436 Views)
Reply
