NI myRIO App Development
Reply
Highlighted
Error 74 using VI Package Builder
I have now finished my code and I'm trying to build my package.  Whenever I try to build my package with VI Package Manager, I get error 74.  I have read the documentation on both the following links:
https://decibel.ni.com/content/docs/DOC-36176
http://forums.jki.net/topic/1999-error-building-package-error-74-on-package-open/
I have also read the common error causes on the JKI website.  After reading all this, I modified my RT code to include the conditional diagram disable structures as indicated.  I don't have any FPGA VIs to worry about.  I have the most recent version of VIPM.
I have also followed all the instructions in this link to build the package:
file:///C:/Users/scoles/Downloads/Tutorial%20-%20myRIO%20Application%20Development%20(2).pdf
After pulling pieces out of my code, I have found that the only way to get rid of the error is to pull out my VI that has references to the myRIO driver.  Even if I just put the open and close VIs into my project and then build it, it will get error 74.
Any ideas what I might be doing wrong?
Certified LabVIEW Architect
(2,134 Views)
Re: Error 74 using VI Package Builder
The first link you referenced contains a further link to the JKI site with a fix for this issue.
Using an Open FPGA Reference to a bitfile instead of an FPGA VI can result in Error 74.  There is a workaround documented here: Error 74 - Open FPGA Ref with .bit File and this issue is fixed in VIPM 2014.
authored by
Christian L, CLA
Principal Partner Development Manager - Partner Program - National Instruments
(1,300 Views)
Thanks for replying so quickly!
I did notice that link earlier, but I ignored it since I am not using the FPGA Open/Close Reference function in my code.  What I did not realize at the time is that the NI-RIO driver functions use those VIs.  I have now followed the solution in the above link, and been able to successfully build my app.  Thanks for your help Christian_L!
(1,300 Views)
Reply
