NI myRIO App Development
Reply
Highlighted
API Key
I'm currently developing a smart sprinkler controller app.  I now have all the base architecture functional, and I am looking to add the smart features.  I am currently adding them by pulling weather data off of wunderground.com.  I wrote my own html parsing function which pulls the data from their page.
My question is about legality.  Weather Underground has an API for which you can purchase a key.  If you make less than 500 API calls per day the key is free.  This works for my computer, however if this code is published, it could potentially be used by many people.  Their webpage also requires you to attribute their webpage for any data that you pull from it by placing their logo somewhere on your app.  The way I see it I have a few options here:
1. Require every user to create their own API key.  Then have the user enter the key into my app so it can pull data.  Also place the wunderground logo in my app.
2. Use the API that I wrote - although they may have a limit on the number of times the page can be called per day.  This shouldn't be a problem since the requests will be coming from different IP addresses, but I want to make sure this is legal before I publish it.  This method could also break if wunderground.com updates their webpage and changes the format of the HTML code.
3. Build the app without the smart features, and just call it a sprinkler controller.
4. Purchase an API key that can be used by many users.  I'm going to assume NI does not have enough of an interest in this market to make it worth it.
Could someone give me some insight into what the proper and legal way to go about pulling this data would be?
Certified LabVIEW Architect
(2,477 Views)
Re: API Key
A 5th option I have is to use Open Weather API, the API is not as complete, but they provide API keys which are completely free for any usage.  I could also use sensors in place of getting water data and temperature.  I already had the other option working and so I didn't think to simply to using this method - though this seems like a good option. I am somewhat curious about the legality of using an API key as I mentioned before, but I think maybe I'll try to use this simplified open source key for now.
(1,675 Views)
Re: API Key
What market do you see this appealing to? To me it seems
the myRIO is going to be adopted primarily by "makers." If that's the case
having them generate their own API key wouldn't just be OK, it might give
them a sense of "Hey, I actually did something and learned something." If
it's aimed at the masses, however, that may not be the case.
Just my $0.02.
fka OlliesCamel
"I have Google for memory and Wikipedia for knowledge, mostly I use my brain for thinking up stupid things for my body to do."
Christopher Stryker | Staff Software Engineer | Certified LabVIEW Architect
(1,675 Views)
Re: API Key
I agree, that the primary market is "makers."  I think it might be nice to have them each generate their own API key - I just wan't sure that requiring users to do something like that was legal (I never have to generate my own API key for apps I get online).  If I just put the wunderground logo into my app to give them credit for the weather data, would that be all I need to do?  I've been playing around with the open source API as well, it's a possible option, but not as thorough.
That said, I don't know that there is a huge market for an app like this at all - it just seemed like something that might be useful.
(1,675 Views)
Re: API Key
Without fully reading the EULA I would guess that having the end user
generate an API key and then including the wunderground logo and credit
would be sufficient.
I wouldn't say it's "common" but I can think of at least 4 or 5 times over
the past couple years that I've had to generate my own API keys. That
being said, I do obscure stuff sometimes.
Chris
To: OlliesCamel <chris.stryker@ni.com>,
Date: 04/28/2014 08:21 AM
Subject: - Re: API Key
Community
Re: API Key
created by Shane-C in NI myRIO App Development - View the full discussion
Reply to this message by replying to this email -or- go to the message on
Community
Start a new discussion in NI myRIO App Development by email or at
Community
fka OlliesCamel
(1,675 Views)
Reply
