06-16-2017 09:39 PM
Hello friends,
my working environment : Matlab 2015b32bit + Veristand 2016 in Window7.
after under the guide:
Problem:
The Windows SDK 7.1 installs the compiler required to create models for Windows and PharLap ETS VeriStand systems. However, setting up the SDK on a Windows 8.1 or 10 machine is prone to failure. What is the recommend installation method for this SDK on Windows 8.1 and Windows 10?
Solution:
The following method has been used to successfully install the SDK 7.1 on both Windows 8.1 and Windows 10:
With the compiler installed successfully, you are ready to compile models for both Windows and PharLap ETS targets.
then, in matlab model can be successfully:
### VeriStand 2016.0.0.72 (2016) code compilation done
### Successful completion of build procedure for model
but the .dll cannot run correctly in Veristand 2016 project. no calculation was executed in VS window or RT machine.
Can anyone help, thanks in advance.
06-21-2017 02:42 AM
Hi wisejohn, I heard a similar problem with Matlab and VeriStand.
Which hardware drive do you install Matlab and VeriStand?
This is the thread in Japanese.
06-28-2017 08:13 PM
Win10,even PC simulation fail!
06-29-2017 10:24 AM
Hello John,
Would you please clarify on what doesn't work?
Have you tested the behavior of a simple and minimal model design? For example, would you please verify that a single multiplication in the model properly executes when stepped in VeriStand.
07-01-2017 03:50 AM
Thanks,see details followed:
MATLAB2015B 32bit,
Model:
config setting:
Build:
VS2016 project and Deployed
runing(no data sine wave or did not work!!!)
07-01-2017 03:51 AM
NestorG 已写:
Hello John,
- Does the model successfully load in System Explorer or does it return an error stating of an incompatibility?
- Or the model loads in System Explorer, but at execution the model's returned data is unexpected.
MATLAB2015B 32bit,
Model:
config setting:
Build:
07-04-2017 02:13 AM
Hi John,
Try, please, using regular Matlab In/Out ports. I have some models compiled with Matlab 2016a for Veristand 2016 and they work like a charm.
07-04-2017 02:41 AM
Regular Matlab In/Outports should work. They must be in top level model.
CLA, CTA, CLED
07-04-2017 10:48 PM
You may use an indicator to check the model state.
07-05-2017 05:05 PM
Hello John,
This is actually a known issue. We fail to export ports if the model only references VeriStand Port blocks. To resolve the issue you must have at least one Simulink Port in the model design.
The only reason to use a VeriStand Port block is if you desire to access the port within a subsystem; otherwise, I encourage you to use Simulink's Port blocks. The Simulink Port blocks offers greater support for various data types than a VeriStand block.
Note that the issue is fixed with the release of VeriStand 2017.
