VeriStand
Veristand & Alarms not working when multi alarm are set
VeriStand can not trigger more one alarm at the same time
Is it a bug or not ?
(6,018 Views)
Hello Lunik,
In the system explorer, you can define Groups of Alarms. In a group, alarms are evaluated sequencially, and alarms in different groups are evaluated in parallel.
Flo
(6,004 Views)
how I should set the alarm response for mutliple alarm ?
(5,998 Views)
Hello Lunik,
It's all depend on what you need 🙂
how do you want to response? and where? on the host side or the RT side?
You may want to call the same procedure for differents alarms triggered
Flo
(5,968 Views)
When i set the same procedure for multi alarms i got only the first alarm and not the other
(5,948 Views)
I've found that if multiple alarms are of the same priority, and one alarm is always being triggered because the condition is continually met, it may prevent the other alarm from triggering. In general I've put a small delay on all alarms so that other alarms will get an opportunity to trigger.
(5,683 Views)
