09-24-2019 05:30 AM
I didn't use VeriStand 2018 for a couple of weeks and now I can not open a project anymore, I've already searched for updates, reinstalled the program, but it still does not work.
For VeriStand 2019, my license is not working. What can I do?
09-24-2019 06:08 AM - edited 09-24-2019 06:09 AM
My private guess is, you've installed cumulative Windows update in the meanwhile which ruined your NIVS installation. The Best what you can do is OS + application (re)installation. But of course you can start troubleshooting with the NI technical support (if you have an active SSP), which will most likely (after quite some time of unsuccessful troubleshooting) end up with a recommendation I proposed above...
09-25-2019 02:37 AM
Thank you for your answer.
I think the Problem is, i need to install the Service Pack, to get the 64 bit Version. But when i want to start the Setup, it says that there is no Service pack installed and it cancels. (what i find completely strange)
what could be the reason for this, or does someone have same Problems?
09-26-2019 04:04 AM
after reinstalling thousend times i can start VeriStand 2018.
But now i have an error, while compiling a Project that was correct a few weeks before:
09-26-2019 10:58 PM
Please check your System Definition File (SDF). Did you add Custom Device into your project?
If you added then, visit
C:\Users\Public\Documents\National Instruments\NI VeriStand 201x\Custom Devices
and check whether there is CD named "Read from Binary File in Engine Data Compilation".
09-27-2019 01:45 AM
Thanks for your answer.
I solved the problem, the reason for the problem were different software versions on my PXI-system and on my desktop computer.
