07-27-2017 06:31 AM - edited 07-27-2017 06:53 AM
Hello all,
I am currently experiencing some issues while trying to replicate a System of ours. This configuration has worked in that exact setup before and now I am experiencing loads of problems. The Project uses a 7811R with a custom personality I wrote last year. Here's what works and what doesn't:
The FPGA code runs on LV FPGA, without any problems.
In VeriStand: When I select just the chassis, it deploys fine.
When I add the 7811R with my own .fpgaconfig it returns an error after starting deployment group 1: Error -50400 Timeout
When I add the 7811R with an example config (e.g. PCI-7811R PWM, Digital Lines.fpgaconfig) it gives me a different error after starting deployment group 1: -61024 Something about a mismatch between configured and current device type.
I can't stress enough, that it all worked before in the exact same configuration.
Because of this I added a 7841R that we had lying around. This deployed just fine with the standard config (PXI-7841R Analog, PWM, Digital Lines.fpgaconfig in this instance).
From the errors or lack thereof described above, I surmise that:
a) The 7811R itself is OK, since it works with LabVIEW
b) VeriStand + FPGA works, as it works with the 7841R
c) All the installed software is OK, as well, since it works with the 7841R
What else can I try?
P.S.: I should mention that the same problem occurs on both my laptop and our demo system. Both are Running VeriStand 2015 SP1.
Solved! Go to Solution.
07-27-2017 08:51 AM - edited 07-27-2017 08:55 AM
Also, the Example config should be: PXI not PCI. Result is not the same.
Edit: It's not, when you select the right RIO device. Now I just need to get my custom personality going.
07-28-2017 03:17 AM
OK, I don't really know what did the trick, but it works now.
After finding out, that I had previously selected the PCI personality instead of the PXI, the old project still wasn't working. So, I created a completely new one, which worked right away. After that, I basically copied my old code into the new project and now it works. The old one still doesn't.
What I don't quite get is: With the new software I get problems when loading the file, because of the Umlauts (üäö). The old version does not complain.
As I said, I don't know what did it in the end. I installed the earlier version of Xilinx (10.1) that might have done it. Also completely rebuilding the project.
