10-19-2020 08:31 AM
I need to use teststand with veristand and to write the sequence I can not use the real target because busy for test so I would try to use a laptop.
I've installed LV2016, VS2016 e TS2016 (32bit) and I'm able to open a VS project.
I set the target has local host e try to deploy but an error occurred (see log).
Any suggestion?
10-20-2020 12:50 AM
The error say the "PXI1Slot11"device is simply not present on your system. You can try to simulate it thru NI-MAX or just for your test disable DAQ devices in your SDF.
10-21-2020 02:51 AM
Hello and sorry for delay in this response.
I've created the peripheral board with MAX (no shelf and controller because in MAX my controller is not available). The board are in same virtual slot of real case.
Now the error is different, seems a synchronization problem.
10-21-2020 03:43 AM
Error found, was due a DAQ setting.
I've checked the "Disable AI Support" and It works
