VeriStand
The Veristand gateway was unable to establish a connection with the target
Hi all,
when I try to run the project on cRIO-9068 I got the error message that shown next.
as I read to use cRIO with veristand the ram should be over 128MB , so as I understand the cRIO-9068 can handle and work with veristand .
also I tried to run the project on windows , the project worked .
I cant figure why this happened with me , I choose the controller operating system to Linux_32 because this is the type that been mentioned on the NI website .
(3,040 Views)
Mohammad,
Have you already tried the troubleshooting steps in this Knowledge article?
Error 63 for System Definition File Cannot Be Deployed to Real-Time (RT) Target from VeriStand
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6BkSAK
(3,015 Views)
Accepted by MohammadOkour
Dear Reyquaza ,
Thank you for response.
I have uninstall the software that been already installed and re-install all the software again from Custom software installation from MAX.
(2,982 Views)
