06-20-2017 11:30 AM
I'm now beginning to learn for building a real-time control system. I have created a very small and simple model (.vi) with LabVIEW 2015 and then converted the model into VeriStand 2015SP1 model (.lvmodel). My real-time system consists two computers: the development PC is a Window 10 laptop, and the target PC is NI PXIe-8820 RT with a card NI PXI-8512/2, and another card is NI PXIe-6341. When i built a project in VeriStand with the model (.lvmodel) to run on my Window 10 laptop, it was ok and i could control the input signal to have the diffirent outputs. But when i built another project with the same model (.lvmodel) to run on the target PC NI-PXIe-8820 RT, it could not to deploy the System Definition file to the target PC and generated an Error -1074384541. I had reinstalled some software of the PXIe-8820 using MAX but after that when i rerun the project, the system has still gave me an message with an Error 1003 and it still could not to deploy the System Definition file to the target. I have spent much time to solve this problem but now it is still not ok. Please tell me what i should do. Thanks!
Solved! Go to Solution.
06-21-2017 02:48 AM - edited 06-21-2017 02:48 AM
06-23-2017 10:03 PM
Pignite, thank you very much!
It is the exact same thing as you said to me! I have added XNET databases and set the CAN's baud rate. After that, the model ran well! Thank you again for your help!
