Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
01-23-2018 04:26 AM
Hello all
I have created a model and I am trying to set a default value for a parameter (optional value in LabView). The field "Default" in the section "Behaviour" is grayed out and I also can't select it in a procedure to initialise on start. Is there another way than setting it through the API, as described here https://forums.ni.com/t5/NI-VeriStand/Set-model-inport-default-value-using-System-Defintion-API/m-p/... ?
Thanks, Raphael
Solved! Go to Solution.
01-23-2018 04:57 AM
Thanks!
We'll be in touch soon!
