NI VeriStand
Scan Engine update rate for 9145 EtherCat Expansion Chassis
We have a PXIe-8840 RT controller and would like to expand our system to include a 9145 with 4 9224 C Series modules.  If our PCL is running at 1kHz, can we use the Scan Engine Custom Device to stream 32 measurements from the 9145 at 1kHz?  Just wondering if there are any bandwidth limitations with this configuration.
(86 Views)
Accepted by topic author holteeww
I would not expect that you would have a problem.  We have run at 1 kHz and higher with over 20 channels in the 9144 EtherCAT chassis, using the VeriStand Scan Engine for EtherCAT custom device.
(43 Views)
Thanks for the response.
(37 Views)
