05-16-2020 04:19 PM
Hello
I'm really appreciated if anyone help me out whether Veristand has network heartbeat functionality on it.
[background]
I use Veristand for HIL with PXI-RT.
For safety reason, I would like to stop other mechanical and electrical facilities when communication between Windows host PC and PXI-RT Target lost for some reasons, such as Windows freeze and Network trouble.
So I would like to detect communication failure on PXI-RT, and then turn off mechanical relay.
Any advice would be greatly appreciated.
thanks regard
06-30-2020 06:22 AM
From where would you actuate the facilities? and how?
06-30-2020 06:40 AM - edited 06-30-2020 06:41 AM
I would simply use a user a channel within your VS project called PC Watchdog and broadcast your host PC heartbeat to this using the workspace manager over the Veristand gateway
I would then have a simple watchdog "model" (I've taken to thinking of these as scripts as they are just a piece of code and dont have to be models) that outputs a boolean high when your watchdog is trippped
You could have an alarm watch this output from your watchdog model that when tripped runs a procedure that closes relays and such as desired
06-30-2020 07:16 AM
I've used this watchdog method: https://forums.ni.com/t5/NI-VeriStand/Configure-Watchdog-in-Veristand/td-p/2717405?profile.language=...
You could adapt it for your needs.
