VeriStand
NIVS via ASAM XIL - MAPort ReadSimultaneously implementation
I'm currently communicating with VeriStand engine using ASAM XIL. I would like to read several channels at the same time. To make sure I get values from the same time step, I would like to use MAPort.ReadSimultaneously method provided by ASAM XIL's interface :
IList<IBaseValue> ReadSimultaneously(IList<string> variableNames, string taskName);
When calling the method, I'm returned a NotImplementedException :
NotImplementedException: The method or operation is not implemented.
   at ASAM.XIL.Implementation.VeriStand.TestBench.MAPort.NIVSMAPort.ReadSimultaneously(IList`1 variableNames, String taskName)
Could someone confirm the method has not been implemented by NI ? Would someone have any advice about how to read several channels simultaneously ?
Thanks for your help !
Jeremie
(2,217 Views)
Hi
Just wondering what version of Veristand you are using?
It seems like ASAM XIL 2.1 support was added in Veristand 2018.
http://zone.ni.com/reference/en-XX/help/372846M-01/veristand/whats_new/
/Kristofer
(2,102 Views)
Hi Kristofer,
I'm using Veristand 2019 and I've been using some features of ASAM XIL 2.1 (framework variables and so on).
Did you manage to make the ReadSimultaneoulsy method work on your side ?
Thank you for your answer.
Jeremie
(2,092 Views)
Getting same error with veristand 2020 too.
Any solution?
(1,859 Views)
