VeriStand
NI Veristand NI XNET with PXIe 8135 and PXI 8513 CAN card
I am using PXIe 8135 embedded CPU with PXI 8513 can card. Now i am trying to set up my first veristand project
I see NI-MAX can show the card and functioning properly.
When i add CAN1 to N1-XNET devices on veristand with example database or the on i copied from another project. i get below message and never deployed !! What could be the reason. I have installed all the drivers properly ( similar to another working PXI setup).
it hangs at this message
Start Date: 6/11/2019 9:33 AM
• Loading System Definition file: C:\PorscheIPB\CANonly\CANonly.nivssdf
• Initializing TCP subsystem...
• Starting TCP Loops...
• Connection established with target Controller.
• Preparing to synchronize with targets...
• Querying the active System Definition file from the targets...
• Stopping TCP loops.
Waiting for TCP loops to shut down...
• TCP loops shut down successfully.
• Unloading System Definition file...
• Connection with target Controller has been lost.
• Start Date: 6/11/2019 9:33 AM
• Preparing to deploy the System Definition to the targets...
• Compiling the System Definition file...
• Sending reset command to all targets...
• Preparing to deploy files to the targets...
• Starting download for target Controller...
• Opening FTP session to IP 10.245.37.66...
• Processing Action on Deploy VIs...
it hangs here for long time and ................................................................................................................
• Deploying XNET database: DCM_7-24_DB
• Gathering target dependency files...
• Downloading CANonly.nivssdf [42 kB] (file 1 of 4)
• Closing FTP session...
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error 1 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
NI-488: Command requires GPIB Controller to be Controller-In-Charge.
NI VeriStand: TCP Write in NI_FTP.lvlib:FTP Command.vi:5860050->NI_FTP.lvlib:FTP [MKD].vi:3150001->FTP.lvlib:FTP MKD Recursively.vi->System Definition Deployment.lvlib:FTP Target Files.vi->System Definition Deployment.lvlib:Check and Deploy Files.vi->System Definition Deployment.lvlib:Deploy Target Files.vi->System Definition Deployment.lvlib:Deployment Dialog.vi->NI VeriStand Server.lvlib:NI VeriStand Server.vi->NI VeriStand Gateway.lvlib:VeriStand Server Wrapper.vi
Can you please help ? what is going on here ?
(1,898 Views)
Hi, the error said that the file you specified couldn't be found on your PC...
When you change the file to following example, do you see the same error?
C:\Users\Public\Documents\National Instruments\NI-XNET\Examples\NIXNET_example.xml
Certified LabVIEW Developer
GCentral
(1,876 Views)
