I'm trying to deploy NI-VeriStand system definition with an EtherCAT custom device into a cRIO 9038, Linux_32_ARM. I am getting the following error.
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error -307608 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
NI VeriStand: The custom device does not provide a valid source distribution for the target specified. Specify a different target or contact the creator of the custom device for further support.
The Scan Engine and EtherCAT 2017 v4.3.1 was used.
