VeriStand
Get timestamp with Veristand from received signals in CAN communication
Chris_Jones_NIUK
wrote in
https://forums.ni.com/t5/NI-VeriStand/CAN-communication-with-Veristand/m-p/3330990 :
"It will also mean that you can add a frame/signal to VeriStand."
If I have added the signal names to get the value of the signal. How can I get the to a signal corresponding timestamp?
Because usually each CAN signal belongs to a CAN message and each CAN message has an timestamp.
(2,455 Views)
I think what you're after is the 'Create Receive Time channel' setting in the Import Options when adding a new can frame:
Chris (CLED, CLA, CTA)
Applications Engineering Specialist
(2,404 Views)
