VeriStand
Get Dependent Node Reference - cRIO target
I have a cRIO-9035 (os:Linux_x64) as RT target and when I use "Get Item Property (Dependent Node Reference)" in the "RT Driver.vi" to retrieve a reference node that I previously set with "Set Item Property (Dependent Node Reference)" in the "Inizialization.vi", I always had an invalid reference  as output value even if the Found output is TRUE (the property exists). Did you have the same issue?
Thanks for your help,
Francesco
(1,998 Views)
Accepted by topic author fra_sab
Hi Francesco,
Are you programming a Custom Device? Have you seen this documents?
ftp://ftp.ni.com/pub/devzone/tut/niveristand_cd_dev_guide.pdf
http://www.ni.com/tutorial/9348/en/
Best regards
I
(1,920 Views)
