NI VeriStand
Error on OpenWorkspace API (Veristand add-on)
Hi all,
I try to implement a simple senquence for veristand using teststand and related add-on.
The sequence is made of only two steps :
StartVeristand => it works without problem
OpenWorkSpace=> It fails with error in attached file
I work without real target (PXI) but if deploy the project on localhost it works
Thanks for any idea and suggestion.
(234 Views)
Accepted by topic author zundap1970
Error found, there was a wrong setting in a API.
(215 Views)
