06-22-2018 12:46 PM - edited 06-22-2018 12:48 PM
I am trying to use the NI VeriStand - Get Parameter Value VI to look up the value of a parameter from the RT target running a system definition file.
I noticed that when running this code with VeriStand 2017, the error code I get is -307994 which is not listed on the VeriStand 2017 manual: http://zone.ni.com/reference/en-XX/help/372846L-01/veristand/vs_error_codes/
Has this error code not been documented yet? I ask this because when using LabView/VeriStand 2013 SP1 on a different machine, I get the error code -307662 (NI VeriStand: Node is not found in the system) which is listed on the error codes page for VeriStand.
06-25-2018 05:25 PM
I found a Corrective Action Request (CAR) related to this error code under CAR #595765. It looks like the error being undefined is a known issue that R&D is addressing.
-Salazar
