VeriStand
Error -307950
Hello everyone,
I'm a newbie in Veristand. I have a project that has correctly worked for a long time. I usually update it and espacially one of its models. But during the last update, when I clicked on the "reloading arrows" I had the following error popup:
I don't really trust the "Possible reason(s)" because there is nothing wrong with my NI Veristand licence server (if it's about it), it is running correctly.
I'd say the problem is about my new revision of the model but does anyone has any precise idea of the origin ? Some more understandable idea ?
Thank you very much !
(4,467 Views)
Hello Luc,
Did you have launch the VeriStand server before deploying your model:
http://zone.ni.com/reference/en-XX/help/372846B-01/veristand/communicating_with_the_veristand_server...
Do you have the same behavior with a really simple model?
The only thing that have change between the time it worked is the model modification or is there anything else (computer change ...)
Valentin
Certified LabVIEW Architect
Certified TestStand Architect
Certified LabWindowsCVI Developer
National Instruments France
(4,436 Views)
Hello Valentin.B,
Thank you for your answer. Actually the error was very trivial. I made a "copy/paste" mistake : I tried to load the .mdl instead of the .dll.
Now it works way better.
Thank you for your answer !
(4,402 Views)
