12-16-2015 04:14 AM
I have a error when searching for devices on my PXIe-8135.
I don't understand where it can com from. NI System Configuration 14.5 is installed on the target.
Is there something missing on the target?
Thanks.
Jean
12-24-2015 12:33 AM
Hi, Jean. I had the same problem with you. Did your problem be solved? If your problem was solved, please reply me and tell me how you solve it. Thanks!
12-24-2015 06:42 AM - edited 12-24-2015 06:43 AM
Hi jay111ln, it seemts that Jean installed TimeSync drivers to his PXIe controller.
You too?
I have heard that installing them causes this trouble.
My suggestion is
- Format your controller
- Install needed software excluding software which are related to TimeSync
Best,
