06-21-2018 08:19 AM
I'm hoping someone can help me with an issue I am experiencing modifying workspace objects in Veristand please?
I don't believe I am trying to do anything overly complicated and in fact it is covered by option 2 of this link http://www.ni.com/tutorial/9989/en/ - "2.Changing the Appearance of a Workspace Object".
One of the problems I am having is that I am using LabVIEW 2015 and Veristand 2014. If I simply modify an existing workspace item and save with a new name, Veristand gives me an error stating that the object isn't compatible when I try to drop it on the workspace.
So I used the option to save as an earlier version, but now I am getting the following error message when I try to drop it on the workspace:
I have tried a few things but to no avail, so any help would be greatly appreciated.
Thanks Si.
06-21-2018 10:49 PM
Hi, I belive your software combination is wrong.
If you are using LabVIEW 2015, you should use VeriStand 2015.
Also using LabVIEW 2014, use VeriStand 2014.
See this compatibility table.
06-21-2018 10:51 PM
06-22-2018 01:53 AM
Ah okay, I was worried that would be the root cause.
So saving my VI (LabVIEW 2015) as an earlier version (LabVIEW 2014) isn't a viable solution?
I suppose I will stick with the standard workspace objects.
Thanks Si?
06-22-2018 02:06 AM
06-26-2018 10:06 PM
06-28-2018 05:28 AM
Unfortunately saving as an older version did not work, but I now have a access to LabVIEW 2014, so I have got around the problem.
Thank you for your help.
Si
