07-17-2012 03:34 PM
I have downloaded and installed evaluation versions of both Labview 2011 and NI Veristand 2011 and am interested in exploring how the two interface with each other as a possible solution for an upcoming project. Based on on-line literature the Custom Device Template should have been installed atC:\...\Labview 2011\vi.lib\NI Veristand\Custom Device Tools\Custom Device Template Tool\Custom Device Template Tool.vi. When I navigate that path there is no "NI Veristand" folder in the vi.lib directory.
Was it installed elsewhere, or is it not installed with the evaluation version?
07-18-2012 07:17 AM
I had a similar problem. I could not find the NI Veristand functions in Labview. I had installed Veristand (evaluation) before Labview (full version) and I was told that I needed to install Labview first.
After unistalling, reinstalling and activating Veristand, everything worked fine.
I also think you need to have the full version of VeriStand, not just the evaluation but I'm not sure.
Hope this help. (sorry, english is not my first language)
03-13-2019 02:56 AM
I can confirm PPrez's advice, because I ran into the same issue.
I reinstalled first my LabView 2017 without getting the Custom Device API libs.
Then I reinstalled VeriStand 2017 and voila, the API was there inside the National Instruments/LabView 2017/vi.lib/NI VeriStand Folder.
Hope this helps someone in the future.
